Old 06-04-2012, 05:08 PM   #25 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Gasoline Fumes View Post
What car and what type of valvetrain? I think you want to keep the oiling system as it was with all the valves. The spacers I used cover the now-unused oil holes in the rocker shafts for the deleted rocker arms. Leaving those holes open could potentially affect oil pressure in the head.
The car is a 2002 Sebring Convertible GTC with a transplanted Chrysler 3.5L V6 engine. It is a SOHC design with 24 valves. For each cylinder, there are two separate intake valve rocker arms, and one combined exhaust valve rocker arm assembly.
If I were to do this, I'd probably go to a junkyard to find a head from a junked 3.5L engine, and get measurements of the pivot shaft, so I can find or fabricate spacers to block off the oil holes as you mentioned.
