Old 06-04-2012, 06:21 PM   #5762 (permalink)
electricstorm
Originally Posted by twotires View Post
Electricstorm,
You can also build a quick voltage divider from 1/4W resistors to fool the control board into believing it's getting a signal back from the current sensor - keeps you from getting the yellow light - then scope the signals at U7 ....
Michael
Thanks for the info Michael!
How many resistors did you use, what values were they, and where did you connect them to on the control board? I am assuming you tapped each point in the divider network to simulate different current levels.
Jim
