Old 06-04-2012, 06:49 PM   #5763 (permalink)
twotires
EcoModding Noob
twotires's Avatar
Electricstorm,
There are 4 pins leading from the control board to the LEM HASS current sensor - pin 1 isn't even hooked up to anything, you can omit it. Pin 4 gets +5V and pin 3 is gnd. Pin 2 is where the output comes back from the sensor. I hooked up two 100k resistors (I think they were - basically any two resistors of equal value), one from pin 4 to pin 2 and one from pin 3 to pin 2. This splits the +5V in exactly half so the 'output' looks like 2.5V so the controller thinks it's hooked up and getting a signal back. Yellow light doesn't light (assuming you have no other problems, unlike mine!) and you can move on to the next test.
Are you near the RTP?
The Following User Says Thank You to twotires For This Useful Post:
electricstorm (06-05-2012)
