Old 06-04-2012, 07:34 PM   #62 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by euromodder View Post
Don't run the tank empty on this mix to get rid of it ASAP.
Top it up as often as you can and dilute the diesel as much as possible if you don't want to drain the tank.
For sure, havent let it go beyond 1/2 tank. wanting to burn it out before i pull the sensors so i wont have to again so soon. Most likely will after 1month to check them to make sure its all gone and sensors still clean.
