Originally Posted by Cd
By the time you smell the odor , there is going to be quite a bit of carbon monoxide in the car.
Might be wise to purchase a battery powered carbon monoxide detector.
I'm still worried about that wood catching on fire !
Why not leave a gap of at the very least 2 - 3" ? Or better yet not have that wood anywhere near the exhaust !
I looks like it weighs quite a bit for what little gain you may get - even if it is eventually attached to a flat bellypan.
the entire structure tops around 20lbs.
Just taking out my 40lbs subwoofer/box would offset any weight i put on. And I wish there was a way to not have the wood there, but underneath the body is very inconsistent. if i cut into the wood more than it already is, would lose all of the boards structural integrity, + no where else to mount too without drilling/tapping into the metal work. <trying to avoid this as much as possible>
If i come up with something better, it will be done asap! Better safe then sorry
