Thank you for the data.
I performed a similar test with Goodyear Integritys (185/65/15) on my old Prius and tire wear was very even at up to 60psi.
Because mpg doesn't significantly increase with pressures higher than sidewall max I tend to stay around the 40-44psi range nowadays.
