Old 06-05-2012, 03:12 PM   #73 (permalink)
offalot
KLR - '07 Kawasaki KLR650
90 day: 49.2 mpg (US)
EVA - '81 Mercedes 300SD Turbo diesel
Mitsubitchy - '02 Mitsubishi Galant
90 day: 28.12 mpg (US)
Olga - '81 VW caddy
90 day: 44.7 mpg (US)
purple toaster - '05 Scion XB
90 day: 35.57 mpg (US)
a torradeira - '06 Scion XB
90 day: 35.44 mpg (US)
Thanks bschloop, Hope I can ride her soon. I have a pallet scale at work so whenever I can take it to work i'll get an accurate reading, till then, bathroom scales it is.
Originally Posted by euromodder View Post
It's the air buffeting on your shoulders, causing minute steering inputs.
Even the BMW R1200R with the small optional BMW windscreen suffered badly because of it.
Try a bigger or smaller screen, or try varying the angle (and with it, the point where the air hits your body).
Other solutions are a small spoiler near the top of a windscreen, or leaving a (bigger) gap at the bottom.
Euromodder, are you saying that it is the wind causing your body to steer the bike erratically? Never thought of that possibility, might be why mine went away when I redesigned the wind screen. I just figured it was turbulence on the front end. So if this theory is correct then you should be able to test it by getting up to 70-80 till you start feeling the buffering, then get into a tuck and it should go away.
