most fuel injected cars 1995 and older work just fine on E60 or so. The higher the compression, the better they are. Hondas are notoriously good with ethanol. I ran e80 or so on a 93 civic.
On any of them, you can extend the amount of ethanol you run by unhooking the vacuum line which runs to the fuel pressure regulator. This will bump your fuel pressure slightly at part throttle letting you run a touch more ethanol.
