Old 06-06-2012, 12:43 AM   #21 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
all cars have lottsa mounting points
all cars have many mounting points for bellypans
look for the round rubber / plastic plugs that fill the holes that were needed for the jigs that lined up under body floor parts during the assembly of the car .
stick a bolt / stud / threaded rod with 2 large washers and nut in the hole
whalla
a very secure , strong , serviceable , mounting point .
cheap
easy
steel beams
the kind that replace 2 x 4 s in construction are very light and very stiff when screwed or welded together and could easily make up ribs or frame work of a belly pan , or just use the steel and nothing else , trim to fit .
very cheaply
you can build one yourself
stop typing on the internet
get under the car
and
do it
The Following 2 Users Say Thank You to mwebb For This Useful Post:
mechman600 (06-06-2012), t vago (06-06-2012)
