Old 06-06-2012, 11:44 AM   #2 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
As far as I can figure, lay a template over each. You want to manage the pressure buildup on the front so you can use it to your advantage at the rear if you have or will have a boat tail. Starting at the top of the windshield will not build the pressure as well as the template would.
I set this up as if there were two different sized vehicles drafting each other at negative distance.
