Old 06-06-2012, 02:54 PM   #34 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by TOOSTUBBORN2FAIL View Post
Looks good, did you do anything to the bumper to get the glass to adhere better? I almost did this back in 09, but the civic that did the foam/fiberglass bumper back then, he had problems with it cracking off of the bumper. The polyester resin doesnt stick to plastic very well. In the audio world, a lot of times, we'll drill a bunch of small holes through the plastic to get it to adhere better.
Actually, I used epoxy resin, which I understand has better adhesion properties than polyester resin to non-porous surfaces like plastics. I haven't had any problems so far (knock on wood).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
TOOSTUBBORN2FAIL (06-06-2012)
