Old 06-06-2012, 06:35 PM   #7 (permalink)
minispeed
minispeed-Insight - '00 Honda Insight
90 day: 82.15 mpg (US)
MDX - '01 Acura MDX Touring
90 day: 22.29 mpg (US)
the wife's car - '13 Toyota Prius Plus
90 day: 45.99 mpg (US)
leaf-one - '15 Nissan Leaf SV
So trial and error, none of the resistors works well enough, the lowest that I got was 560ohm 1/4w. The LEDs still light up but they are very dim. It reads 2.5v when I test it after the resistor and testing it causes the LEDs to turn off. Since they are only $1 for a pack I will go back and test some smaller resistors.
I did as above and tested the current, I found when wired up just the LEDs on a 12v source (it's raining out so I didn't want to go test with the car running and had a 12v inside) 131.2mA for 1 LED strip, 6.7mA when the resister is wired in series.
