Old 06-06-2012, 08:26 PM   #1 (permalink)
mcbrems
mcbrems's Avatar
P914 EV - '74 Porsche 914
Zivan NG3 Charger - 115VAC input, 144VDC output - $630
$630
Zivan High Frequency Battery Charger NG3
Item is used and in very good condition, perfectly functioning.
Label states output of 144VDC at 11 amps, although factory sticker on side indicates charging of
various types of flooded lead acid batteries up to 172 volts (see picture).
Charger can be shipped to Zivan USA to be factory set to custom voltages and tailored to your
particular battery chemistry - AGM, Gel, Flooded SLA, Ni-Cad, NiMH, Lithium or any other rechargeable
battery that may come on to the market in the future. I have not verified, but have been told this can be
done by Zivan for less than $100.
eBay *******s won't let me insert a link here, but you can check out www-DOT-zivanusa-DOT-com.
This unit will not accept 220VAC input, but can be used with public charging stations that provide
110VAC to the car, and also charged from a normal 110VAC outlet at your home or at your workplace.
I accidentally bought this used charger thinking it would work with my 220 volt charging station, and I am
selling it to buy one that does.
Here is a link showing the selling price of a new Zivan NG3:
www-DOT-electricmotorsport-DOT-com/store/ems_ev_parts_chargers_zivan_ng-3-DOT-php
User manual download is here:
www-DOT-zivanusa-DOT-com/pdf/NG3-DOT-pdf
Dimensions: 16.92" L x 8.66" W x 3.54" H
Weight: 5.5 kg = 12.2 lbs
Thanks for looking.
Sorry, new users are not permitted to post links in their signatures.
