Old 06-08-2012, 11:41 AM   #22 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by vtec-e View Post
Would it not be the same as leaving the temp dial set to cold? Like we've always done it? Or are we talking about removing the heater core completely? Because thats a bit excessive, given that most of us need it!
older vehicles with A/C had a factory heater bypass valve installed. Newer vehicles do not. All well and good, except for the fact that there's still heat going into the cabin of the newer vehicle.
All we're talking about is installing a valve to bypass the coolant flow through the heater core during summer months, and during warmup.
Generally, one could get about a 10 to 15 degree colder discharge temperature coming out of the A/C, with a heater bypass in place. As for warmups? I'm not entirely sure a heater bypass would provide any sort of measurable decrease in warm-up time.
The Following User Says Thank You to t vago For This Useful Post:
brent777 (06-10-2012)
