Originally Posted by A.D.D.
The tires are TOYO... 195/55/16 fronts have 30.5 psi and the valve caps say: "N2"...so maybe filled with nitrogen? Rears are 30 exactly.
What's the use of N2 when your tyres are flat
They use green caps to indicate N2 in the tyres on this side of the Atlantic.
Looking at the top grille and it does NOTHING... the radiator is at the bottom. the Top grille is for looks.
Block it !
I also wanted to see 40 mpg. **Cue Music** (mission impossible)!
I wouldn't call it impossible
Looks like you have your goal set now
