Old 06-09-2012, 02:01 PM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Gealii View Post
The rpms still climb evenly with the speed even at higher rpms.
Then it doesn't seem to be slipping.
Clutches obviously wear down over time, and then start being a bit less smooth, or start to catch earlier on when you release the pedal again ... that's wear, but it doesn't mean it's shot.
which is what I'm thinking is that it's just worn cuz of the test i did
You won't wear down a clutch with a test
It takes prolonged abuse before it'll fail.
Just remember it's only there to shift gears, getting started from a stop, and do some REALLY SLOW manouvring.
Try to make smooth shifts without being on the clutch for too long, and it'll last a long, long time.
