Old 06-10-2012, 03:20 AM   #26 (permalink)
baldlobo
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
Originally Posted by ecomodded View Post
The second key characteristic of a stroker kit versus OEM is the required changes to allow a stroked crank to 'fit'. This is accomplished in one of three ways:
▪ Location of the piston pin (and the top of the rod) within the piston, or the compression height is shortened.
▪ Length of the rod is shortened.
▪ Height of the cylinder is lengthened.
In case you missed that - Length of the rod is shortened-
Stroker kit - Wikipedia, the free encyclopedia
1.yup, not done by dicing up a piston and welding it back together
2.yup, not done by dicing up con-rods and welding back together
3.haven't seen it done(most commonly by sleeving)
incase you missed it cast metal shouldn't be welded
besides off-set grinding cranks need smaller internal diameter bearing surfaces(which would be best accomplished by different rods); then you have to think about oiling passages,etc...
