Originally Posted by t vago
Well, if you install a bypass and don't properly remove all of the air out of your cooling system afterward, then it is possible to do some major engine damage. Not terribly likely, but it is possible.
However, if the bypass is properly installed, and the coolant system is properly burped of air, then the bypass itself should not cause any problems.
okay sweet no prob can do
thanks for the q and a
