Originally Posted by BackroadBomber
Depends on the code. I had a f150 that had a running lean code (fuel pump only giving off 24psi) and I was getting 17mpg. Put in a new fuel pump, fixed the code but only got 15mpg
correct, but running lean will kill burn up your engine
