Old 06-11-2012, 12:26 PM   #8 (permalink)
NeilBlanchard
Looks good -- is there holes in the chin area ahead of the radiator? If so, you can block them up so that the air that goes in the grill all goes through the radiator; and you might even be able to have smaller openings in the lower grill.
You should add some foam gasket to seal the hood gap, too.
