Old 06-12-2012, 12:05 AM   #1 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
VW 2.0 8v block (2003 Beetle) can I use it under a diesel head?
Where can I figure out the compression numbers, etc?
I've got the block, the head will fit, and the stock manifold from the 2.0 fits the 1.6D head and can bolt on a K03 turbo (not sure it'll fit where I need it to, but it opens up options anyway).
Just wondering if the 2.0 block will work. Hopefully it'll see a modest compression boost and more low-end torque than the anemic 1.6D had originally, and I've got to rebuild the 1.6D engine no matter what. This block has 40k on it and blew a head gasket, so 2 and 3 pistons are scored with water damage along the edges, but parts are cheap, and the pistons look like good dishes.
