Old 06-04-2008, 11:36 AM   #2 (permalink)
Daox
If you are going to be blocking off large portions of your radiator you should really get a scangauge or other device to monitor the coolant temperature. The dummy gauge on your dash isn't accurate enough to closely monitor coolant temps to see if your fan is turning on and off (in which case you'll loose FE).
