The rear axle beams do not line up for the mounts. They're not off by much, and I COULD make them work, but the Aspire rear beam has larger brakes, bolts right in, and uses all the same hardware, so it's kind of a moot point.
I'm going to use heim joints for the steering and the OEM Festiva rack & pinion.
