I disconnected injection wire, leaving VSS connected: it shows the speed only.
And for curiosity, i swapped Inj and VSS: i got it to show nearly truthful values, including instant
But now, naturally, it picks the speed from injector, and injector from speed sensor, so it wont work. I will swap them back.
Could the other values in settings affect the instant? Could injector delayµs affect that? I gotta try to fiddle with that.
The "current l/100km" is stabilizing slowly, sometimes from 200l/100 to 11-6l/100. Meaning that it updates too slowly, i think. And that's how injector delay adjusting would work?
EDIT: Yea, adjusting injector delay did work. Now i only need to calibrate it better. It was 500µs default, 150 does not display instant, 140 does. Any suggestions for this? Just testing, testing...?
