Originally Posted by UFO
I don't like the MAF twist method as it affects the MAF output across the entire load range, not just at idle where the EGR function is verified. It would be easy enough, given the temperature input, to switch the EGR in or out with a relay.
I hope I will have the opportunity to take another long road trip from Denver to Crestone. I got 51mpg on B100 with the EGR defeated. I may go again in late summer; if I do, I will re-connect the EGR and compare.
I don't particularly like the MAF twist method either for those reasons. Although, for quick testing purposes it may be helpful. Did you incorporate a temperature dependent On-Off to your EGR delete? Are you noticing an increase in engine responsiveness from the EGR delete?
