Old 06-13-2012, 10:33 AM   #1 (permalink)
mikehallbackhoe
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
grill block delete
since the weather has warmed up, I have noticed in my crx ,that the fan will come on when I shut the engine off, and the fan will continue to run for quite a while. the coolant level is full, and the temp gauge is not registering hot. I am assuming my grill block is causing the fan to run longer than normal. I removed the grill today to and will see if this fixes the problem. I also recorded my worst mpg this last tank. maybe the alternator is working harder to recharge the battery, or under hood temps are too high.
