The new 1.0 Ford ecoboost is cast iron. Aluminum absorbs heat 4 times as fast as cast iron, so you may find that there will be a cast iron "comeback" in engines since you would expect the manufacturers to minimise the heat radiated to the atmosphere, expecially with frequent engine off cycling.
regards
mech
