Old 06-14-2012, 09:58 AM   #9 (permalink)
gone-ot
...beats walking...
Originally Posted by Old Mechanic View Post
The new 1.0 Ford ecoboost is cast iron. Aluminum absorbs heat 4 times as fast as cast iron, so you may find that there will be a cast iton "comeback" in engines since you would expect the manufacturers to minimise the heat radiated to the atmosphere, expecially with frequent engine off cycling.
regards
mech
...exactly, especially with more & more vehicles using "idle stop" controls; want the engine to "stay" in 'closed-loop' operation as long as possible instead of having to break 'loop' with each "stop."
