Old 06-14-2012, 12:12 PM   #5 (permalink)
mikehallbackhoe
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
I use the dash gauge to check temp. I also check the water level. If it is not losing water, it is noty running too hot. the crx came stock with a partial grill block, so I may only need the full grill block in the winter. since I diligently
check mpg at every fillup, I will be able to determine if mileage goes up or down . I do know that my last tank, with the full upper grill block in place, was my worst tank , @ 50.54 mpg. lt is usually in the high 50's, so this was a significant drop.
