Thread
Mk2 Golf Kamm back - foam it or coroplast?
06-14-2012, 06:44 PM
5
permalink
JethroBodine
MPG Militia HMV-25E80+A
FrankenJetta D
- '90 Volkswagen Jetta GL
Diesel
90 day:
64.35
mpg (US)
My
OPINION
would be to go with option 3 and heat form some lexan and make a flat closure on the back side, paint-match the upper part and leave the rear clear.
If you do use spray foam, let it sit about a week before covering it with anything( even paint) as this will give it time to FULLY cure and won't bubble/warp like my tail is doing right now because I rushed to get it semi finished before the SMCC Rally this last weekend. After a week you can use fiberglass resin to make it tough as nails, and then sand to shape as you see fit.
Coroplast is fun to work with and can be made to do some funky things as some of the artists around here have accomplished with a little creative engineering
. Closing the end with lexan will give you the full benefit of view and solid rear face.
Hope that muddies the waters even further
and I can't wait to see what you come up with
It is always very amusing how our imagination is put to the test when overcoming reality.
Redyaris
Boat tail project
How to gently bump start during EOC
JethroBodine
View Public Profile
Send a private message to JethroBodine
Find More Posts by JethroBodine
