Old 06-14-2012, 10:10 PM   #14 (permalink)
Flakbadger
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Originally Posted by 3-Wheeler View Post
I would think about using the aluminum engine in the following manner:
Keep engine aluminum for less rolling mass
Use active radiator block to help maintain heat loss
Use engine underbody panel for same reason
Side affect of above, you get a lower Cd to boot.
Jim.
Actually doesn't sound crazy to me. I've kind of wondered about having an aluminum heat-sink type radiator for a car before... Sort of like the cooling fins on fancy PC RAM or on R/C car's motors. They'd probably need a regular radiator for low-or-no-speed operation, but it could be a lot smaller with the passive cooling the heat sink would provide.
It'd burn the hell out of you if you went to change the oil, though :P
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
The Following User Says Thank You to Flakbadger For This Useful Post:
Christ (06-15-2012)
