Old 06-14-2012, 11:25 PM   #5766 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
I tested out that big inductor (48 pounds) with the nichrome wire (4 strands of 12 gauge each). The nichrome was 0.14 Ohms and was in a big bucket of water. It was just liike a motor! Perfect current control. I could even ramp up the duty to 100%. I tested it out on a controller kit that was sent to me to test. At 100% duty, at 24v it was using about 170 amps. I also ordered some more Nichrome so I could do higher voltage testing, and keep the current from going into the stratosphere. It really works as a good motor simulation. Plus you don't have to worry about the motor running away when testing new controllers that fail ON.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
electricstorm (06-17-2012)
