Old 06-14-2012, 11:49 PM   #120 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Electric motor fitting
I describe myself as lazy. I don't do a lot of work that I think I can get by without doing (excluding safety).
I started out thinking that I'd need to make a model of the electric motor and use that model to determine if the motor will fit into the engine and transmission bay of SalvageS10.
In preparation to make the model, I measured up the electric motor. The motor cylinder is 15.5 inches in diameter and 19.5 inches long. Add the 5.5 inch motor shaft, 2.375 inches in diameter. This does not match the NEMA measurements for my T frame motor exactly, but it's close.
I then took rough measurements of the space in the truck. It is 32 inches front to back, from the firewall to the inside of the air conditioning radiator. That gives 7 inches of clearance. The coupler to the drive shaft will take some of that room, but it should be at a bit of an angle and end up in the tunnel formerly occupied by the transmission. The width is 16 inches from center to center on the motor mounts. The electric motor is 15.5 inches wide so there is a bunch of room there as well. The motor Junction box sticks out 5.5 inches on one side, but the space is wider as it goes higher.
If things get tight, I can get another inch or two by removing the air conditioning radiator. I don't think that the air will ever run again in SalvageS10 ... but i won't remove it unless I need to.
I don't think that an accurate model of the motor is required. I may still make a cardboard model that is a bit larger than the actual electric motor to see if I can install the electric motor from below and avoid lifting the motor in from the top ... but that would be in a while
