Wonderjava...check out PTCrew. They are performance guys who know the PT inside and out. Truth is; if you have an auto 2.4L N/A PT you are only asking for serious issues if you turbo it. If you want more power and want a PT...sell yours and buy a PT GT. If you are hell bent on keeping your current PT...then an engine swap and transaxle swap are really your only options. A V6 would be hard to fit in a PT especially if you are inexperienced with swaps, fabrication, engineering in general.
NoD is spot on...reduce PT weight is really your only good option with your current drive-train setup. Remove the rear seats, get low weight rims/wheels.
