Old 06-15-2012, 01:20 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by F8L View Post
I just thought I would post up my recent results after switching out 2 other sets of LRR tires for the Energy Saver A/S.
I found that I was averaging about 3-4mpg higher with the Energy Saver A/S than either of the Yokohamas which were very similar in mpg to each other.
Not bad, considering Toyota already put some LRR tyres on the Prius.
In tests, the Continental EcoContact 5 did even better, but it's only just hitting the markets here.
Just thought I'd share what a good set of tires can do for fuel economy. Pressure is set at 44/42psi.
What's the sidewall rating ?
On the European version it's 51 psi.
Though at 44 you'll already have the greater part of the possible fuel savings.
Here is a pic of my return 98% freeway commute (@60mph) from 1,200' ASL to 50' ASL.
Wow.
