Old 06-15-2012, 06:54 PM   #12 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by mcamphr View Post
Thanks I'll look into the Ultragauge - I wondered when I bought the car whether this was the original tranny. I asked about the engine and the previous owner replied that it was original - my rpms seem to settle around 2500rpm at 65mph and at 61 mph around 2300rpm. Not sure if this is normal. Most of my driving is a commute to work at 70 miles one way - I generally avoid the stop and go of traffic by leaving early in the AM and leaving earlier in the afternoon. But, it does feel like I should be posting higher numbers. Thanks - I may not know for sure until I get a MPG gauge inplace. Now, I'm second guessing my decision to remove the rear spoiler again that can be one I test with a mpg gauge.
That's right where it should be for an HX. You're lucky; my EX with shorter gears and final drive sits at 3000rpm at 65mph! 50mpg should be easy for you with some aero mods.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
