• increasing tire diameter is same as lowering final drive (axle) ratio = lower engine RPMs for given speed.
• increasing PSI trades ride comfort for less tire resistance = better MPG.
• increased tire LOAD rating typically increases tire weight = not good for MPG.
• LRR is overall tire "rolling resistance" = better MPG, but typically at slight expense of handling and wet road control.
