the biggest factor for mileage is pressure, the higher you can keep the pressure the better, safely of course. LRR tires are great, but dont be fooled!! some tires will sacrifice traction for rolling resistance, do your homework extensively. personally, i would keep the size that is stock. also, i've heard great things about the michelin energy saver a/s tires.
