Thread: light wheels
Old 06-18-2012, 02:33 AM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Sporty Modder View Post
IIRC for every 1 lb of rotating weight it is the equvialant of removing 7 lbs from the chassis. That being said, for each wheel you replace its like removing 100 lbs from your car.
This is only partially correct. It's a "starting point" for people to understand and make functional changes, but it's not even close to a strict rule of weight reduction.
WHERE you take the weight from has more to do with total performance than HOW MUCH weight you take off.
