No matter what method you use your still going to have throttle losses when creating a vacume. Cylinder deactivation has been around for awhile and has been documented in that reduces fuel consumption at part throttle operation. I think removing the throttle restriction compleatly and injecting fuel on as needed basis for less then full power needs would achieve this. Think of the hit and miss engines of days gone by.
