Vago, those covers look like a good idea. If the pizza pans stay you have it made!
In other news, my truck went through a hailstorm last Monday and broke 2 blades on one of my front mounted radiator fans. Vibration was so bad even with it windmilling that I had to remove it. So, this weekend I installed a used Taurus 3.8L e-fan. Learned the hard way I wired it backwards, so it was pushing warm air out the front inside of pulling it through the radiator. Got it rewired and on low speed, it works very well. Keeps temperatures more stable than the previous fans, and nearly as good as the clutch fan. Haven't wired up the high speed part yet, but figure I can get to that before I start towing later this summer...
Turns out one or two of my wheels are out of balance, not the fault of the 0.100" LEXAN covers.
Reason: vibration detected...
