Old 06-18-2012, 08:29 PM   #166 (permalink)
lsemple
looking to get 100mpg
lsemple's Avatar
Si Civic - '93 Honda Civic Si
90 day: 41.16 mpg (US)
Originally Posted by steffen707 View Post
I'm fairly certain your car being a 93 civic won't get fuel if you inturrupt the black ground wire that supplies the main relay. That stops the fuel pump and the fuel injectors from getting a signal from the ecu to fire. I did this same setup on my 92 civic, should be the same.
Right, but my main problem with this is that I have a fuel vaporizer which delivers fuel vapors into my PCV hose. So, the engine will still be getting fuel.
(now that I think about it I wonder if I could run only on fumes. might burn out the engine though),
anyways, this is why I need to use a different wire, like the crank position sensor.
I would love to be able to mimic exactly the electrical circumstances that take place when I turn the key back a notch to the ACC position, then back to the run position. This way the car will be ready to fire back up when I release the clutch pedal in 5th gear !
