Old 06-18-2012, 10:39 PM   #20 (permalink)
Duffman
Originally Posted by t vago View Post
What would that do for exhaust? I can't advance the intake lobes by themselves. The truck engine is a SOHC design.
You would have to experiment or gets some advanced engine software, you would have to think the original engineers did a fairly decent job to start with. You could buy a after market cam with a wider lobe separation angle or LDA.
That's not really possible without spending hundreds (or thousands) of dollars into having a custom, one-off intake manifold fabricated. All sorts of things have to be taken into consideration: airflow into the individual runners, interaction between cylinders, effects of different engine speeds on airflow.... Not something I want to focus on, right now.
You can epoxy the manifold for peanuts but again, you may dump a huge amount of high RPM flow for tiny gains on the low end. Again the original engineers probably have your engine dialed in pretty well already.
