You can harvest them, but avoid eBay if there is a junkyard in your area. I bought all of the terminals/ connectors I needed for around 5 bucks and spent a couple hours splicing it all together. Finding a legit vx harness is hard. But using the connectors from other crashed hondas( not just civics btw) is doable. Finding the ecu in the junkyard was the only part I couldn't find. Good luck
