Old 06-04-2008, 04:40 PM   #118 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
yeah but I DONT want the CA or High Alt tranny, I want the true 5th gear of the HF the one that nets 51mpg stock.. if that page I spotted is correct its a easy swap of the fifth gear.. if not ill go to 155/80-15 tires for a 10% gain.
The difference in mileage is 5-6 mpg with the shorter 5th gear.. I want the really tall one. no sense in making all these mods to the areo then revving the engine at 2250 to go 55-60 mph when the drag is cut down so much.. just waisting gas at that point.
Doesn't matter to much at this point I got lots of areo work to do .. and even if its not a simple gear swap without dropping the tranny, I can always just swap tires and wheels to get a better final drive ratio.. the goal is to lower the revs as much as possible for any given speed once areo mods are done. The motor in the 1st gen of the crx isnt a rpm hogg.. they really weeken out in the upper RPM range they were tuned for that really tall fifth , low rpm and torque there bit not up on the top of the rpm range... totally opisite of the honda engines you see iin the newer hondas..
but if any one spots a first gen HF tranny with the .0655 fifth gear set, I'd be willing to make it worth your time to get the set and ship it to me
