Originally Posted by skyking
What are the measurements?
My truck runs from 10.5" to about 13", for example.
It measures 15 inches in the front, to 18 inches at the rear of the camper body, 25 feet back, and then up to 28 inches at the rear of the boat tail, 4 1/2 feet or so further back at the end of the boat tail.
The steep departure angle is necessary because of the off roading I do with it. Before I modified and extended the hitch, the bottom of the boat tail was about 34 inches off the ground, so that part of it is 'improved' dramatically.
I'm surprised the difference is only 3 inches over the length of the actual body, I thought it was much more than that.
