Old 06-19-2012, 01:29 PM   #2 (permalink)
Soichiro
Elise - '13 Hyundai Elantra GLS
I use the pressure monitoring valve stem caps, and they work well and are only about $10 for a set of four. The limiting factor is that I've only seen them available in 32 and 36 PSI. So if your recommended PSI on your trailer is above 36, they won't help you so much. They certainly do simplify checking your tire pressure, though, so they would be good for this purpose.
