Old 06-19-2012, 02:38 PM   #74 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Leave a hole for that trailer. I see your posts, and observe that when you really use this RV you are towing.
Yes, make a frame for each panel, hinge it, and have the ability to fold it flat.
Put an x-brace across the corners at the back to stiffen it up. If you do it as nice as you did the first work, it could be deployed in couple of minutes.
It will not block the tail lights of license plate either.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
