Old 06-19-2012, 08:18 PM   #5 (permalink)
pete c
A little more info. The tires are cooper trendsetter SEs. P195/75R/14. Load rating is 1400 lbs. Max pressure 35 PSI.
The camper weighs right around 6000 lbs. Assuming 70% of that weight is on the rears, each tire has a little over 1000 lbs on it, so I should be OK.
I think I will try running them at 40 PSI and get a set of the 36 PSI valve stem pressure monitors.
