Old 06-20-2012, 09:24 AM   #8 (permalink)
pete c
I will see if I can find such a placard. I do know for a fact that the recommended tire is the 185R14D. That comes from many different knowledgable toyota motorhome owners. The RV companies bought these as cab and chassises from toyota, so they could list something different as they could have ended up as box trucks or whatever.
I will see if I can find a highway scale to get a better idea of what the actual weight is.
The spacers is an interesting idea, but, rather than spend the money there, I think I would just put it into proper tires. Also, with the tires at normal pressure, I measure a little over one inch clearance between them. So, clearnce shouldn't be an issue assuming I stay on top of proper inflation pressure. And if I can get a set of the monitors for 10 bucks, that would be money well spent.
